create tunnel ipv6-in-ipv4
create tunnel tunnel_name ipv6-in-ipv4 destination destination-address source source-address
Description
Creates an IPv6-in-IPv4 (6in4) tunnel.
Syntax Description
tunnel_name Specifies an IPv6 tunnel.
source-address Specifies an IPv4 address for the tunnel.
Default
N/A.
Usage Guidelines
This command creates a new IPv6-in-IPv4 (otherwise known as a configured tunnel or a 6in4 tunnel) and add it to the system. A maximum of 255 tunnels (including one 6to4 tunnel) can be configured on the system.
The tunnel name must be unique and cannot overlap the same name space as VLANs, other tunnels, or VRs. The name must begin with an alphabetical character and may contain alphanumeric characters and underscores ( _ ), but it cannot contain spaces. The maximum allowed length for a name is 32 characters. For name creation guidelines and a list of reserved names, see Object Names in the Switch Engine v33.1.1 User Guide .
The source address of the tunnel must be one of the IPv4 addresses already configured on the switch. You cannot remove an IPv4 address from the switch if a tunnel is still exists that uses it.
The following example creates the 6in4 tunnel "link39" with destination address 10.10.10.10 and source address 192.168.10.15:
create tunnel link39 ipv6-in-ipv4 destination 10.10.10.10 source 192.168.10.15
Platform Availability
This command is available on the platforms listed for the IPv6 interworking feature in the Switch Engine v33.1.1 Licensing Guide document.
